bp injectors
projectmx316
bp injectors
hey all i was wounderin if i could use the bp injectors for my 94 1.6 dohc or what injectors could i use that are better than the stock. thank guys
- Limegreen mx-3
u can use bp injecters on a sohc mx-3 i know that the dohc mx-3 injecters would not work on the sohc mx-3. but hey give it a try thats what i did yrs ago. but i dought it would work right, try 4cly injecters from a mx-6.
- TREVO123
Where could these injectors be located at to buy?
- Limegreen mx-3
local junkyard
If memory servers right they are 10cc higher, the FS probe motor's are 20cc's higher.
Although I will say getting more fuel into the combustion chamber does not make more power, you have to get enough air in there as well to use it. Most stock injector setups have more than enough to handle the power added from basic bolt ons.
-torp.
I don't own a Mazda.
- MXL (germany)
mxl
I use the BP DOHC injectors (brown top) in my B6 DOHC...you shouldnt take the Injectors from a BP SOHC....they are similar to the B6 SOHC.
.....in European cars!
E A S T S I D E C U S T O M S
LINK to pictures, video and technical dates (english): http://www.mx-3-community.de/home.php?id=299/
