is it possible....look
- TREVO123
Is it possible to put a stroker kit on a BP that is a 1.8L to make it a 2.0L?is the engine block and walls thick and strong enough to do it?hopefully that all makes sense..
Re: is it possible....look
I seem to remember there being a kit out there to do so but its rather costly. From hersey i have heard form many sources going up to a 1.9l is pushing the limits of the motor. A BP is a stretched B6 so its close to its limits as is.TREVO123 wrote:Is it possible to put a stroker kit on a BP that is a 1.8L to make it a 2.0L?is the engine block and walls thick and strong enough to do it?hopefully that all makes sense..
-torp.
I don't own a Mazda.
- Limegreen mx-3
Racing mazda does it too.
- happyclown
I dunno much about it, but there is an old crazy lookin lady who lives a ways down the street, She's got two OLD a$$ caddies that just sit in her lawn and she drives around in a BOSS 2.3 Escort
Its got the 95 ish body, the one that I would expect to see the BP's in. I don't know if the BOSS 2.3 on the car is for shits and giggles or if there really is a 2.3 that could swap in... or if she put a kit to it...
i have not been able to find any 2.3's to drop in to it...
1993 RS Teal
- Josh
their are several kits available, the FM kit is the most expensive from what i understand. The BP has alot more room to bore than the 1.6 will ever have (unsleved). so is their room yes definatly. and enough cylinder wall left to boost very happilytorpedan wrote:I seem to remember there being a kit out there to do so but its rather costly. From hersey i have heard form many sources going up to a 1.9l is pushing the limits of the motor. A BP is a stretched B6 so its close to its limits as is.TREVO123 wrote:Is it possible to put a stroker kit on a BP that is a 1.8L to make it a 2.0L?is the engine block and walls thick and strong enough to do it?hopefully that all makes sense..
