tranny
- fieromx3
tranny
ok ive searched and i read that you can use the 2.5 litre kl-de tranny this is correct? it also said that the wiring is different. so if i got the kl-de tranny could i just use the ecu and tranny wiring harness and all work? what about the axals they ''bolt'' up to it no probs? im asking this becua the availability for the k8 atx is VERY low only found 2 of them...
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- XxantwawnxX
Axels will fit np...everything wll fit (not sure on wiring) umm i might be wrong but i think 5th gear is longer.
- XxantwawnxX
Ohhhhh...i thought that might be the case. but since you did not mention i decided to go with it. Hmm i know nothing about the atx...
- Aston Wards
I've asked around, and been told there is no way it'll fit....., but then again there was a fellow AGES back that said he had one in his car?!
Unfortunately, even if you could get it to work, they still aren't a particularly reliable transmission...., we see plenty of KF/KL powered cars with rooted trannies.
I guess if you have either money or an engineering background you might want to have a go, otherwise let it be....
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
- fieromx3
o this really sux cuz ive searched the net and both the k8 tranny and kl-de tranny have the same gear ratios and heard they are pretty much the same except the 2.5 tranny is ''beefed'' up in a couple ways.....i know they are still crappy trannys but i need one temporarily and i can get one for 100 bucks so i think i might give it a go after i do more research
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- Aston Wards
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Ive seen in the wreakers a lot and i mean a lot! of 2.5 trannies thatfieromx3 wrote:o this really sux cuz ive searched the net and both the k8 tranny and kl-de tranny have the same gear ratios and heard they are pretty much the same except the 2.5 tranny is ''beefed'' up in a couple ways.....i know they are still crappy trannys but i need one temporarily and i can get one for 100 bucks so i think i might give it a go after i do more research
have kicked it, they an't beefier by any means.
Mannual conversion time perhaps???
