EL PASOS FINEST GSR GIS 'ER
- PWRD_BY_HKS
IN CASE YOU DONT REMEBER ME THIS IS RUDY FROM EL PASO DISTRICT WITH THE 13 SECOND MX -3 AS YOU MIGHT REMEBER I BLEW MY MOTOR A WHILE BACK I FINALLY SAVED UP SOME FLOW AND I THINK I WILL ONCE AGAIN BE EL PASOS FASTEST AND FINEST GSR...... MY SWAP WILL INCLUDE A ZE MOTOR OF COURSE, A FORD PROBE TRANNY ... (ITS ONLY LIKE A 200 RPM DIFFERENCE FROM STOCK SO DONT EXPECT TO MUCH FROM THAT), FUEL PUMP, LAST TIME I RAN MY ZE I HAD A K8 MANIFOLD BECAUSE STRAIGH NECK DID NOT FIT THIS TIME I GOT A CURVE NECK ZE....... SO IM BACK BETTER THAN EVER ILL KEEP YOU POSTED .... EYYY O WHAT UP HEC I TOLD YOU ID GET IT DONE AGAIN ...... HEC IS A WITNESS TO MY MONSTER IM OUT
-jdMX3 KID
-jdMX3 KID
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- jschrauwen
Red Rocket
- mitmaks
well post some pics
- MX-3 Money
But what does GIS 'ER mean? And dude needs to turn of the caps lock or cut down on the coffee. Does el pasos have a lot of mx-3 with ze's or even mx-3's?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
lakersfan1
- MX3 GSR for dummies
P O W E R E D B Y H K S.........what the intakejschrauwen wrote:What is a "GSR GIS 'ER"?
oh and props to custommx3...
Sorry to harp on ya El pasos! hey he's got a gun....run to the border!!!!!!!
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
Blew the motor eh? Ouch
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
hgallegos915
rudy this time dont over rev it..these engines are prone to valve float and when I opened your old ze, piston number six had a HUGE hole in it and the rings where broken in most pistins.. ine head was destroyed and the other one was stuck in the block. TAKE IT EASY THIS TIME
and enjoy. 2 blown engines in a 1 year period is no goood . I still got my spare k8 which im putting in a mazda van or something anywho keep us posted.
-hec
- PWRD_BY_HKS
Look mann i dont know why you are hatin on me that it completly foul of all th mx -3 drivers and if you dont know what a gsr mx-3 is just sell it moron!!! and yes there are some mx-3s here this is not hick ville retard. dont worry -hec ill let you know whats up hey mann by the way give me a call bro i lost your number
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- PATDIESEL
Were not hatin' in a bad way Bro. You just need to learn how to use grammer and the caps lock button. It is hard to read what you write.
Good luck on the GSR.
