Fuel Injected (Before 95)
1 Ignition Pulse.
2 Distributor - No 2 Signal.
2 No 2 Signal (626 and MX-6).
2 Crank Angle Sensor - No 2 Signal (1992-1995 929, MX-3 1.8L).
3 Distributor - G or G1 Signal.
3 Crank Angle Sensor - G Signal (MX-3 1.8L).
4 Distributor - No #1 Signal or G2 Signal.
4 Crank Angle Sensor - No 1 Signal (MX-3 1.8L).
5 Knock Sensor.
6 Vehicle Speed Sensor.
6 Air Flow Meter (MX-3 1.8L).
7 Knock Sensor - right hand side.
8 Air Flow Meter.
9 Water Thermo Sensor.
10 Intake Air Thermo Sensor - Air Flow Meter.
11 Intake Air Thermo Sensor - Dynamic Chamber.
12 Throttle Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor or Heated Oxygen Sensor - left hand side.
16 EGR Position/Function Sensor.
17 Feedback System or Closed Loop System - left hand side.
23 Oxygen Sensor or Heated Oxygen Sensor - right hand side.
24 Feedback System or Closed Loop System - right hand side.
25 Solenoid Valve - Pressure Regulator.
26 Solenoid Valve.
27 Solenoid Valve.
28 Solenoid Valve - EGR Vacuum side.
29 Solenoid Valve - EGR Vent side.
30 Cold Start Injector Relay.
34 IAC Valve.
36 Heated Oxygen Sensor - right hand side.
37 Heated Oxygen Sensor - left hand side.
40 Solenoid Valve - Triple Induction Control System & 02S Replay.
40 Solenoid Valve - Variable Resonance Induction System Solenoid Valve - VRIS 1.
42 Wastegate Solenoid Valve.
46 Solenoid Valve - VRIS 2.
65 A/C Signal - PCMT.
67 Coolant Fan Relay No. 1.
69 ECT Sensor.
Reset ur ECU (disconnect battery for a couple of minutes. Negative side), hold brake for a bit in that time.
If the code comes back try, replacing ur cap and rotor (cheap).
But I'm sure somebody else knows for sure.......................
good luck
