Page 1 of 2
deck help please!!!
Posted: December 31st, 2005, 5:38 pm
by kevio180
Hi guys, I got my deck installed today along with my screen, but when I press the gas, its making a mad high pitched sound, kinda like driving a electrical car, lol.
I'm thinking it might be because I didn't ground the 2 wires probly, if thats the case, is there a nice sopt I can ground it with out cutting myself reaching for it?
Or if its somthing else?
Thanks
Posted: December 31st, 2005, 7:53 pm
by FlyVFR
For shame
Always ground the ground wires
Find a bolt on the chasiss. Or if you have the installation manual that came with your unit follow their procedure.
Have a nice day
Posted: December 31st, 2005, 8:53 pm
by kevio180
I did ground them, just not on the car, lol, more like on a pecice of metal.
Can both wires be grounded to the same bolt? or do they have to be far apart?
thanks
Posted: December 31st, 2005, 9:05 pm
by FlyVFR
Posted: December 31st, 2005, 11:41 pm
by kevio180
lol, wicked, thanks, I will try to fix it tommoorrow
Posted: January 1st, 2006, 9:35 am
by kevio180
Cool, its done. I wired them to a spare clap and hooked that on to a metal part inside the dash, sounds great now, screen working great too. thanks
Posted: January 1st, 2006, 9:58 pm
by kevio180
ok, right now, if I play at a low sound level, like around 3 to 5, i can still hear that high pitched sound, but not very loud, not as loud as before. But if I play it normal, like above level 7, i can't hear it anymore, i know its there, just not loud enough for me to hear.
is it suppose to be like that? or is there somthing i can do to get ride of it?
Posted: January 2nd, 2006, 10:44 pm
by FlyVFR
You may want to visit your local Car Audio Shop, they will hook you up with a small device called a noise filter or some other nifty gadget that may be new on the market to eliminate alternator noise. Keep me posted.
BTW- make sure the ground wires are secured properly making a good connection and not loose.
Posted: January 3rd, 2006, 7:21 pm
by kevio180
Cool, thanks. the noise isn't borthering me, just affrde if it can do some damage. I will go pick up a filrter, the ground wire is sercure, but i will check again, thanks alot
Posted: January 3rd, 2006, 11:30 pm
by FlyVFR
Glad to help. Enjoy
Posted: January 5th, 2006, 5:58 pm
by RoundTop
I simply used the ground from the factory deck with mine. I cut the end and spliced the wires, then soldered it together for a good connection and then taped the end.
(I soldered all my deck wires to the harness... makes for nice good connections)
Posted: January 5th, 2006, 6:34 pm
by FlyVFR
RoundTop wrote:I cut the end and spliced the wires, then soldered it together for a good connection and then taped the end.
Wire nuts work well also.
Posted: January 5th, 2006, 9:40 pm
by kevio180
Cool, i guess i will try that, if i can find it again, i have no idea where the wire went after i disconnected. Thanks
Posted: January 6th, 2006, 1:30 pm
by Legato626
I would rather solder them that is stronger the wire nuts will come off soder wont.
Posted: January 6th, 2006, 1:36 pm
by RoundTop
Wire nuts are good until you have 10 in a small space... then they suck, and they get caught on things.
Inline soldering (so the wires look strait) and wrapping means a smaller bundle, so easier to do.
After I did that I taped all my wires together too so they are pretty, won't get caught on anything, and don't take up much room.
One warning: the ground wire is a larger gauge wire than the deck wires, so if you are using a stripper instead of a blade, watch out for the thickness.
Aside: I'm enjoying my new Pioneer DEH-P4600MP. For $150 CDN it is nice. (Especially since I'm running stock speakers in the rear and decent 6.5s in the front, why spend more when I would have to put more money into the rest of it to make a difference)
