Has any one ever installed a KLZE in a MX3 thats after the 92 virsion?
I understand there are problems when using the ECU.
How do you get round these problems?
KLZE in newer versions of the MX3?
- garfy1981
Mines a " M " plate and Ze wired up with no problem. OBD1 tho. Unfortunately I dont know the answer to your question mate. Maybe your harness wont work with the KL-36 or KL-31 ecu's. Hence your unable to fire up a Ze lump. ?? So how to get more poke out of the K8 ??.
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
