Changing the lights behind the dashboard dials?
STAINLESS STEEL
I want to change the normal green lights behind the dash and the ventilation nobs to blue ones. Is it the actual lights that I have to change or the actual dials?
And please don't tell me to get the white racing dials, with the blue lights (don't like them very much), unless the dials are black.
Thanks
Thanks
Probably both unfortunately... Have a look at this topic
http://teameunos.com/forums/viewtopic.p ... =dash+blue
- Kokiriwave
no they are bulbs....there are two sizes though..the smaller size is 74....
If you decided to do this make sure you have enough bulbs with spares....just in case...
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
- ovendenk
there is also a green tint behind the gauge faces. also, the bulbs are clear bulbs, but they have a green filter on them that you can remove. i know because i pulled the filter off and put the bulbs back in and the gauges were STILL green. if you take out the bulbs and shine a flash light through, you'll see what grants and i mean.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
STAINLESS STEEL
- ovendenk
i think the back of the gauges are painted with this green tint. you'd have to figure out what color when passed through a green filter will give you blue. either that or aftermarket gauges. speedhut.com has great options.
STAINLESS STEEL
- FIMotorMX-3
I was a little upset when I took off the green caps on my nice clear bulbs in my dash, come to find out now I just have a lighter shade of green lights..... Thanks Mazda..... All I wanted was white lights instead of green...
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
- FlyVFR
Plexiglass acrylic sheets come in different colors. I've seen yellow colored sheets available.STAINLESS STEEL wrote:I know that you mix blue and yellow to make green, so the bulb idea wouldn't work. I'll have to change both.
Thanks
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
Was wondering
Was wondering how you got on stainless? I too would like to have blue gauges but dont like the white facia on the aftermarket ones. Any one have an old cluster that they can take apart and investigate this? Try the yellow filter and see if it makes blue or remove the green one ?????
