Alternator Belt Tightening
how do you tighten it it's too loose again and is squeeling so someone give me the 411
Has it come loose a alot?
I had that problem for a while and even broke several belts, 2 in one week one time.
The problem was with the alternator working too hard to keep power up. I upgraded the ground system and the problem went away.
I was going through belts almost once a week before that. Now I have had the same belt over 2 years.
If the squealing problem comes back, try it.
I ran a thick ground cable fom one of the alternator's mounting bolts straight to the battery's ground terminal
Hope this helps you out.
![Welder :welder:](./images/smilies/welder.gif)
