Clutch?
Clutch?
well just got my Cat looked at and it isnt that, i got a huge powerloss and it feels like the clutch has been slipping. like ill have horrible acceleration then bam itll pull alot then set back down when i start out. I got no power in 5th and im at too high of rpms for what i should be. i got 100k on that clutch so i wonder if i should replace it with a stage 1 racing clutch? or would my problems be else where
StylinMike
- ryanlindenberg
yea if you punch it and the RPMs raise quick while speed goes up slowly you have a bad or misadjusted clutch.
CARDOMAIN WITH UPDATED PICS
well i know my clutch isnt completely out cuz if i let it idle then put it into third then let off the brake and when im falling back i let off the clutch and it pops so i know it works. but ya my rpms climb but no power basically. were gonna try some other stuff before we buy a new clutch just to make sure....like my car needs to shift wayy too early, and by the time im in fifth i have no power left over and im at 3500 at 60
- ryanlindenberg
it's your clutch...and if it was "completely out" your car wouldn't move at all. unless you got out and pushed.
- ryanlindenberg
i think exedy is pretty much the same as a stock one. if you are looking for performance i would recommend an ACT stage 1.
mxprecidia
Carmaster2005
