Page 1 of 2
Probe engine parts
Posted: October 11th, 2005, 12:55 pm
by havoc13
what kind of probe engine parts can fit on my gs engine because its parts day at the wreckers near my house and there is a couple probes! Will the throttlebody work is it anybigger?
Posted: October 11th, 2005, 1:03 pm
by Custommx3
Not sure if that TB will mount up to your TB, but the IM will fit.. barley. I had a KL IM on my KFZE. Almost everything else will mount up as far as engine goes aside from the mounts and exhaust. Drivetrain is different except for the tranny, its the same as you have if you have a 5-speed.
Posted: October 11th, 2005, 1:20 pm
by hppwdn
You think a probe shifter would work in a GS?
Posted: October 11th, 2005, 1:33 pm
by PATDIESEL
Maybe, but I've never heard of anyone using one and from what I can tell they are different part numbers from manufacturers of aftermarket ones meaning that thay are different in some way.
Posted: October 11th, 2005, 1:34 pm
by jschrauwen
Don't bother with the Probe stuff if you can get MX stuff. Drive an extra 15 minutes or so to the huge j/y on the north side of 401 at the Courtice Rd. exit (Oshawa/Whitby). Last count there was 9 to 10 MX's there to pick through. Pull and pick Saturday mornings til noon. Exact name eludes me but will edit when I remember.
Posted: October 11th, 2005, 4:12 pm
by lakersfan1
All the sensors. Power steering pump, alternator, and distributor. AC compressor. transmission. Crank in conjuction with the rods. Oil pump. Lifters. Cams. Cam caps. Valve covers. Head bolts. All the seals and gaskets except the head gasket. All the timing components. Accessory belts and pulleys. Flywheel. Intake manifold in conjuction with the throttle body.
Did I miss anything?
Posted: October 11th, 2005, 8:11 pm
by Custommx3
you miss my mommy.. :) j/k
Posted: October 11th, 2005, 8:48 pm
by hgallegos915
hey try on the straight neck, ive always been wondering what gains would come from a k8 that has a straight neck.. im assuming theres some :D
Posted: October 11th, 2005, 9:05 pm
by fieromx3
well hgallegos im puttin my kl-de IM on my k8 and im takin it to the track friday so ill see how it goes last time i did 17.5 but since then ive gotte larger exhaustpipin and also its alot colder now but we'll see.
Posted: October 12th, 2005, 12:01 am
by Spinkx79
jschrauwen wrote: Exact name eludes me but will edit when I remember.
Doms
Posted: October 12th, 2005, 9:31 am
by Custommx3
hgallegos915...
Your referring to a KL intake as a straight neck.
a KL intake is in the back left, k8 is on the back right, and a KFZE straight neck is down front. (same thing as a KLZE straight neck aside from round instead of square runners.)
Posted: October 12th, 2005, 9:51 am
by PATDIESEL
Barry, "you miss my mommy"...That is like a slap to yourself... :lol: :lol:
Posted: October 12th, 2005, 11:13 am
by Custommx3
Doh! I ment to say, you miss YOUR mommy!
I guess I had 1 too many that night, lol.
Posted: October 13th, 2005, 12:23 am
by jschrauwen
Custommx3 wrote:Doh! I ment to say, you miss YOUR mommy!
:laugh: :laugh: :laugh:
Posted: October 14th, 2005, 3:57 am
by Kokiriwave
Will the black vaccum chambers for the vris from a probe work on the k8...I vacum lines connect differently... vris connects to the far passenger side vacum box in the k8 version...but when i used the probe chamber it connected to the driver side vacum chamber...I'm talking about the black chambers that are bolted underneath the IM...the vacum connections for it are different....My idle is a bit jumpy sometimes, and i get the egr CEL on when i'm under 3500 RPM
Do you guys think it could be the chamber?
