having trouble in the middle of swap
- MAZDASPEEDMX-3
im in the middle of my ze swap and i was puting the flywheel from my old k8 on the ze and i cant remember where or how this little spacer type thing goes its about 2 or 3 inches around and about 2 cms thick with holes just like the flywheel for bolts and me being an idiot as always i didnt pay good atention when i was taking off the flywheel so i didnt know how it went on and i tryed it one way and i ended up shatering the spacer....if anybody knows what im talking about please help me out i need to finish this car and its driving me crazy...thanks
- PATDIESEL
If you shattered it trying one way then the answer is easy, put it on the other way when you get a new spacer...
Best I remember it goes behind the fhywheel. (between the flywheel and the motor)
- MAZDASPEEDMX-3
is it automatic? I got one... if its auto. As far ans flywheel and engine if u got manual..there is no spacer. just flywheel then straight cam shaft
-hec
- MAZDASPEEDMX-3
No spacer on flywheel and manual tranny. Take a look on this link! http://mx3ze.blogspot.com/
yup no spacer...dam thats a ze with quitea few miles ...anywho... theres only a spacer if its automatic..i took one off the kfze when i took off the auto flywheel. The manual one just sits on top.. Im guerssing what you can cal a spacer is that little bearing in the center?
-hec
- MAZDASPEEDMX-3
- MAZDASPEEDMX-3
yeah dump the ze spacer..you dont need it! just swap everything from the old k8 in it.. im almost done with mine!
-hec
