Best Swap Engine for a MX-3 1.6L Engine
I need to know whats the best engine with the biggest power for my car and that it is not to difficult to install!!!
- Josh
you will find the absolute best swap with very little dificulties and the most power is going to be from a 4.6L Mustang Cobra. the 2000 model, NO SHITIN YA.
or you can go to the MX-3 . com home page and look under engine swaps.
![Welder :welder:](./images/smilies/welder.gif)
- atlantamx3
I think your username is the right answer to THIs answer...WTF wrote:KL-ZE, mean engine swap if done right. Easy easy in the 14 second club.
WTF??
The ZE swap is loads more work.
The 1.8L BP swap is literally a Drop-in/ Bolt-in as long as you have a 92/93.
It CAN be done in the 94+ with a little more work.
easy or not...
I never said is an easy swap. I am saying that IF done right will be easy easy in the 14 second club.
Plenty of people do the swap in Puerto Rico and come up with incredible good results.
Its not the part that is bad, but the piece behind the steering wheel that is defective.
How can I remove Mazda Enthusiast?
if you get all the parts from a pull it yourself place it shouldnt be to much more then a bpt swap. Im going from v6 to bpt and all i need is a few things more from the pull it junkyard and axles. A guy on clubprotege just went from bp to klde and made a parts list so he could help you out with it. but in my opinion the bpt is a better engine.
94 green rs
92 black gs project bpt. daily driven bpt in a gs...lovin the boost
http://www.clubprotege.com/forum/showthread.php?t=18065
It not to bad but my car isnt running yet so i cant really talk.
94 green rs
- BuGS
Re: easy or not...
I have to agree. Many 4 cyl MX-3's in PR are doing KL-ZE swaps into their cars for less than BPT swaps. I talked to two already.WTF wrote:I never said is an easy swap. I am saying that IF done right will be easy easy in the 14 second club.
- papa roached
from what i have seen 99% of the fastes MX-3s are BP powered and if i had it to over again i would have got a RS or swaped the BPT into my GS
