jschrauwen wrote:Ya, big time high idle. TPS adjustment time for a start. Also, I've noticed with a fair amount of new ZE installs is that the throttle cable routing needs to be freed up a bit and allowed to go straight over the IM and curve back to the firewall so as to have the straightest and least restrictive path possible
Thanks for the tips....I definitely need to start looking into my idle issues more. I know when the garage did my swap they noted it was tricky getting the throttle cable to reach...very tight. It's weird.....from a cold start, or if I blip the throttle, it will start at/go down to about 900RPM (the RPM I set the air adjustment screw on the TB for), but then wait a few seconds and it'll surge back up to a steady 1400-1500. On top of the high idle, it sometimes 'wanders' like there's a vacuum leak or something. More research for me.
In any case, when I'm not idling, engine performs great. In fact, I definitely surprised a guy in a Lotus Elise last night. He was with his girl and all so I'm sure he wasn't looking to race anyone, but I think the last car he expected to blow by him was a little ol' MX-3.
