whine thing
mx3greg
whine thing
Post by mx3greg »
i test drove this mx3 the other day, when i shifted up or geared down it made this whining noise that sounded really really weird. (like a jet engine)?.. im really not sure what it is, should i be concerned in buying it? it wouldnt matter just that everyone stares at you haha. but id like to know what it is and how i can fix it? how much it would cost? thanks
ccreech
Post by ccreech »
Sounds clutch related since it happens when you shift. I would guess pilot or throwout bearing or just the rivits of the clutch itself making noise.
93 GS KLZE Straight Neck (Parked)
Green Turd of MOCA
Car Domain
mx3greg
Post by mx3greg »
its more a matter of happens when i accelerate or decelerate... sounds like a jet engine or something.
ccreech
Post by ccreech »
Very likely that its a vacum leak then. I had a bad leak around my intake manifold and it sounded like a screaming cricket.
Green Turd of MOCA
Car Domain
g0t_slack
Post by g0t_slack »
I'd stay away from it...
Just today the tranny went out in my 93 Geo Prism.
2 days ago it started making the exact same noise, and yes, only when accelerating/deaccelerating.
DavidOS
Post by DavidOS »
whining sounds normally are from the tranny, for example put it in reverse and reverse it same sounds come.
neutral
Post by neutral »
mx3greg wrote:its more a matter of happens when i accelerate or decelerate... sounds like a jet engine or something.
ppl often use the "jet engine" sound, to describe a wheel bearing that is wearing out. Less a whining and more like a rumbly/roaring noise that happens on acceleration and decel. That might be the prob.
Image -Jim
V8KOMX3
Post by V8KOMX3 »
could be the alternator 2 or radio noies does it have aftermarket radio?
Teal 1993 MX3GSZE
