Cruise control
purewhitemp5
Cruise control
I have a 92 gs without cruise control. Now I have access to a pristine precedia gs with cruise control what I want to know is what I need to take from the precedia to make my gs have cruise control. do I need the whole wiring harness or just a part of it . and is there anything on the engine (a touchy subject at the wrecking yard, unless your buying the engine)that i will need.Also will I need the whole steering colum or can I just take the wiring harness. which ever is easiest.
- jschrauwen
Re: Cruise control
Have you put this question to your nearest Mazda shop? You haven't mentioned that you have tried a search in the old/archived posts. You are aware that there's a plethera of information available by using the search function? Let us know how your search went and we'll go from there.purewhitemp5 wrote:I have a 92 gs without cruise control. Now I have access to a pristine precedia gs with cruise control what I want to know is what I need to take from the precedia to make my gs have cruise control. do I need the whole wiring harness or just a part of it . and is there anything on the engine (a touchy subject at the wrecking yard, unless your buying the engine)that i will need.Also will I need the whole steering colum or can I just take the wiring harness. which ever is easiest.
purewhitemp5
ANYone else looking to add cruise control make sure you grab the main wiring harness from the donar car as the cruise control is a part of it. unlike the power windows and locks where you just need the harness extentions in the doors. also I found it easier to grab the whole steering column rather than take it apart at the junk yard.
