Electrical genius needed!!
Posted: June 23rd, 2005, 6:32 pm
by Mazderati
I have no ignition, no dash lights, no signal lights, hazards work, sunroof works, and door open sensor works. WTF?? I have checked all fuses inside and in the engine comp. All are ok. ( I may have fried something while trying to fix my drivers power window switch.) Is there a relay these are all on?
Any suggestions where to start?
Help!
Thanks in advance.
Posted: June 24th, 2005, 1:26 am
by V8KOMX3
check the fuses would be where I would start
Posted: June 24th, 2005, 1:56 am
by Grants
Go to my web site below and have a look at "info - 1995 wiring diagrams". You might want to print out page 20 - Power Distribution.
From the diagram have a look at what actually does work on your car, (find something common on the drawings with whats working) and you might be able to trace backwards to the likely fault.
The fault actually sounds like it should be fairly easy to find....
Get back to us if theres anything else.
Posted: June 24th, 2005, 10:18 am
by Mazderati
Thanks Grant, I've been to your website and am trying to use the diagrams as you say. However, I am sure you can tell from my posts, I will not be awarded the "electronics genius 2005" award this year. I am taking the car into a tech this morning, I'll give him the diagrams and then I'll post the results this aft.
All fuses in car ok 100% for sure.
Thanks again for your feedback.
Posted: June 24th, 2005, 10:27 am
by Grants
Man thats a shame to have to take it in but I'm sure they'll find the problem ok. Hoping it isn't much - shouldn't be - sounds so bad it should be a major component so therefore obvious (if you know what I mean). Luck with it and please let us know.
Posted: June 24th, 2005, 9:08 pm
by Mazderati
Posted: June 26th, 2005, 2:18 pm
by freyguy_412
Did the fan work before you took it in? Take it back to them and say they need to fix the damn fan. Here where I live, the cheapest rates for electrical work is $70 per hour, and personally if I was going to spend $210 on a wire job EVERYTHING better be workin when I get it back lol. Just my opinion.
Posted: June 26th, 2005, 9:26 pm
by manowar821
God damnit, take the car back and make them fix it..
I am so sick of hearing about people coming back from a mechanic and saying it's fixed and it's not.
Don't let them charge you anything, unless it's a missing part or something stupid like that.
Posted: June 27th, 2005, 1:07 pm
by blkmx3ze
good luck bro
Posted: June 27th, 2005, 11:39 pm
by Mazderati
