I dont think it would look too good on the mx3. The front is ugly to me. And i think the mx3 is to short of a car fo that wicked side kit..but you never know.
yyyyup...he's makin it alright, its comming along...look under the thread "Wide body kit i'm bbAAACCKKK" for updtaes on it. And s--- those rims have some seriouse off-set...sheesh...
actually that supra (one from superstreet) had it's body custom made by a shop.. so.. sorry dude. the kit that is being immitated by an mx3 guy currently is off an ABFlug (i think) supra kit. crazy a-- designs.. and if you gave it to a custom body shop they would do it, but you need deep pockets.
