How to remove a headunit of Sony XR-U110
Car Stereo/Alarm Discussions
kkyin
Post by kkyin »
Do I need any special equipment for that?
And, the unit has a CD button, but it's only a cassette player, what is that used for?
reaper of souls
Post by reaper of souls »
you should just have to pop off the faceplate and there should be two tabs like slots on either side most of the time you can shove a coat hanger in there and unhook the clips and the unit should slide out. worse case pull off the center console cover and grab hold and reaf it out if your upgrading you'll get a new din sleave to mount to and if you happen to break the lower little plasitc bar super glue works great!!!
Image 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
Grants
BANNED Member
Post by Grants »
kkyin
Post by kkyin »
The installed one is the XR-U110, not stock radio.
http://i19.ebayimg.com/03/i/04/14/18/af_1_b.JPG
I cannot seems to find anything holes on the panel.
reaper of souls
oh ya grab and pull!!!!! no there should be two little slots on the side grants pics of the hanger will work for it it'll just be a bit tricker you also have to pull off the little trim ring around the face plate
Typhoonk
Post by Typhoonk »
Looks like an older sony deck. One of the first detachable faces. I bet the trim that surrounds the detachable face is attached to the radio and doesn't come off.
but:
With the face off. Look at the top of the deck just below the trim. U will see two slots, one on either side of the deck. They will be horizontal.
U will need two thin peices of metal to slide in there to unclip the clips.
Where u from? maybe someone in your area have the old sony keys for the deck. (they are thin metal, with round tips, while the newer keys are square and look like JVC keys)
PM for info
kkyin
Post by kkyin »
Let me put a picture of the front with the faceplate off.
So is the rectangular hole on near the upper right corner of hole for the cassette the right one (right above the screw)? Where is the other one then?
Thanks,
BTW, I'm in Atlanta.
Here's the image
http://img190.echo.cx/my.php?image=cddeck25xr.jpg
Typhoonk
Post by Typhoonk »
Ok, no horizontal slots on that one!!! it's not that old
See if you can pop the trim off with a flat head screwdriver
or Reach your hand around the back and see if you can push the deck out.
PM for info
kkyin
Post by kkyin »
ok. I can to push it from behind, but only the tab that holds the deck to the bracket on the right is popping out, any idea on how to release whatever that is holding the deck to the bracket on the left side?
Return to “Car Stereo/Alarm”
