I have put intrak lowering springs on my car with the ZX2 struts. The ride is alright, but when ever i go over a bump i get noise on all four sturts(all around the car). What would you guys recommend doing suspension wise to give me a good stiff ride. Whats a good but not to expensive setup? I also know you get waht u paid for. I hate the ZX2 to be honest, to much roll. I want something stiffer and maybe even a lil lower. Any advice would be greatly apprieciated.
Thanks,
Chris
Question for you Suspension guys!!!!
change your springs to eibach, or your struts to something that can handle the softer spring rate
- Mazderati
I put the Eibach Pro Kit spring setup with the ZX2 S/R springs. I'm quite happy with the ride.
96 GS, 17" Niche's, Falken 40's. Eibach springs, Tokico S/R struts, Ractive front & rear strutbars. Supertrapp exhaust, K & N intake. Soundstream Reference, JL & Eclipse audio.
Green means "Go", Yellow means, "Go Faster"!!
