13.806 @ 102.42
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
rebel2k4
13.806 @ 102.42
Post by rebel2k4 »
Little disappointed I guess. I'm working my way down, but that still sucks.
Here's the break down:
r/t .392
60' 2.245
330 6.028
1/8 9.034
MPH 82.21
1000 11.619
1/4 13.806
MPH 102.42
According to the NHRA, 5300 ft requires a .9 sec correction. So that says 12.9 at sea level. I'm at 5900 ft though. Either way, I'm not sure how right their correction is, but that IS the NHRA I suppose...
http://www.nhra.com/tech_specs/altitude.html
This run was made with slicks. Had to feather the clutch from 4.5k or else i get wheelhop (already have ZX2 struts and filled mounts too)
Pass was done on 9-10 psi. I got an exhaust made this time too ;)
98 Ford Ranger 3.0L
mitmaks
Post by mitmaks »
thats not too bad, youll get there
Juans_93_MX3
Post by Juans_93_MX3 »
Thats actually pretty good, how much power are you making to the wheels now with your latest mods?
How was your launch?
2008 Mazda 3
1993 MX3 GS
rebel2k4
Post by rebel2k4 »
Well, with latest mods last dyno was 269 whp on 8 psi.
I was pushing 9-10 psi, and my car gains 15 hp at the least per psi, so I'd say I was right at 300 whp.
Launch sucked. It launches hard, but I think the part thats costing me .2-.3 tenths is trying to find the "sweet spot" as I feather out the clutch. I'll try a couple clutch dumps anyways next time and hope for no wheelhop.
Thanks for the comments guys. Next go round, maybe I'll get a tuned 15 psi run in.
Possible twin turbo setup in consideration right now.
98 Ford Ranger 3.0L
Juans_93_MX3
One more question
When you hit boost or your peak horsepower and torque, does you car loose more traction?
I'm just curious because I seen some other peoples turboed setups and by the time they hit about 3k - 4k RPMs, their hp/tq goes up by alot
2008 Mazda 3
1993 MX3 GS
rebel2k4
Post by rebel2k4 »
Here's how it goes...
roll in 1st gear, 20 mph ~4k rpm
punch it, shift 2nd hard, rpms sit at 7k and the tires just spin all the way through. It leaves a 30-40 ft 2 tire patch everytime. It's insane really.
3rd gear rolls I do not lose traction. 2nd gear roll, when it hits about 5k I get a little squabbling of the tires.
On slicks, traction problems are non existant.
98 Ford Ranger 3.0L
rebel2k4
Post by rebel2k4 »
Here's the plot.
98 Ford Ranger 3.0L
Slammed6
Post by Slammed6 »
Just outta curiosity what kind of weight reduction do you have?? if any. And have you weighed your car??
Those are some nice times man :thup:
rebel2k4
Post by rebel2k4 »
Slammed6 wrote:Just outta curiosity what kind of weight reduction do you have?? if any. And have you weighed your car??
Thanks.
Yes I have weighed it. I have no done any weight reductions, probably the only thing worth mentioning is that the cat is removed.
I weigh 140 lbs and with me the car weighs 2720. So, 2580 is what it weighs.
I still have full interior, a/c, airbags, etc. It's a street car :)
98 Ford Ranger 3.0L
Slammed6
Post by Slammed6 »
thats good to hear. I plan on running a ZE with 100 shot of nitrous, and tons of weight reduction. I plan on getting the car down to about 2100-2200 Lbs. So i hope to see as nice of times as you have.
Juans_93_MX3
Slammed6 wrote:thats good to hear. I plan on running a ZE with 100 shot of nitrous, and tons of weight reduction. I plan on getting the car down to about 2100-2200 Lbs. So i hope to see as nice of times as you have.
Stock internals on the ZE?
2008 Mazda 3
1993 MX3 GS
Slammed6
Post by Slammed6 »
Yes sir, I have been running a 100 shot for years on my KLDE, and have been running at 125 on it for less than 2 months, this is in my 1994 MX-6...so the MX-3 ZE i am putting together i'm going ZE with nitrous :D
Custommx3
Site Administrator
Post by Custommx3 »
Nice Job though, cant wait to see you hit 12's
Gro Harlem
Post by Gro Harlem »
what tires you rockin?
DONATE TO MX-3.COM
mx3mikey
Post by mx3mikey »
That is still an AWESOME time!
Return to “Drag Strip/Track Racing”
