I need a compatible ecu for my 96 v6...
MOSES
Post by MOSES »
i need to know if a 92 v6 ecu will be compatible with my 96 v6,
if not, what ecu's will work in my car???
thanks again all
Custommx3
Site Administrator
Post by Custommx3 »
Probably no, since 96+ was OBDII
Yopu may have to get the same ECU as you had in it before.
mxmaz
Post by mxmaz »
Yup its gotta be obdII and from an mx-3. No other cars have a compatible ecu with it. It will have to be from a 96 as well cause that is the only year guaranteed to be obdII. Just make sure the number on your ecu is the same as on the new one you buy
MOSES
Post by MOSES »
thanks guys, i geuss ill start looking for a 96 ecu, if anyone reads this post and has one for sale, pm me!
thanks again
MOSES
Post by MOSES »
so the number that has to be the same would be the, (k8...) number, or is there another number im missing?
MOSES
Post by MOSES »
if anyone has one give me a pm, or reply.
Spinkx79
Post by Spinkx79 »
What are you trying to do?
If your ECU is pooched and your trying to replace it, then get the same one.
If your trying to revert to OBD1 to get a ZE in or to ditch your EGR, then you have another option.
You can swap the entire harness out from an older car, you cant swap just the engine harness because all other pinouts are wrong somethig like 45 out of 68 are wrong.
If your interested i have all the pin outs and color codes for most K-series cars.
I will be swapping to something not sure what yet, my plans keep changing.
I am putting a 97 PGT 2.5l into my 96 MX-3 (OBDII). I want minimal down time so i covered all bases.
I have:
97 PGT MTX ECU (OBDII)
94 MX-6 ECU MTX (OBDI)
94 MXT Full Harness
g/l
MOSES
Post by MOSES »
I just need a replacment ecu because mine is dead.
I need to get the same computer that was in it before.
And im not sure where to begin looking
mxmaz
Post by mxmaz »
there is a bunch on car-part.com
Expensive though, $140
MOSES
Post by MOSES »
thanks mxmaz,
that site is awsome, I have one on order already, thanks everyone.
