KLZE Swap - Extra Millenia IM Vacuum/Solenoid Stuff
Posted: May 10th, 2005, 6:55 pm
Hey Guys,
I posted earlier about the KLZE swap I'm having done...the new engine's been prepped and things are moving along (I'll post re: that in a different thread soon). Question the garage doing the swap had for me was in regards to the intake manifold to put on the KLZE. I told them to use the new Millenia one that came with the engine, of course. They weren't sure if they should use it when they pulled it, though, because of the differences between the old and new in terms of vacuum line hookups and extra electronics they found attached to the new one. They weren't sure how to accomodate these differences (or the best way, anyways).
Now I know Gro had a thread on this subject over a year ago, so I hope I'm not rehashing something that's common knowledge. I know there are various IMs and I don't know if anyone had a known approach/solution to the particular one I've got.
In any case, below are pictures of the old K8 manifold, and then my new Millenia manifold. I've highlighted the Millenia picture to indicate the extra hardware that's not on the K8 manifold. Another item of note is that there are remnants of some wiring harness attached to this hardware, but of course it's been severed short from when the engine was pulled from the original car it came from. Thanks in advance for any advice on this!
K8 Manifold:
![Image](http://68.61.35.237/intake_manifold_k8.jpg)
New Millenia Manifold:
![Image](http://68.61.35.237/intake_manifold_klze_marked.jpg)
K8 Manifold:
