Swap help
vozaday2000
Swap help
Post by vozaday2000 »
hey i need some help with these hoses.
they are the last hoses i need to hook up and i can't remember where they go. if the pics didn't come up please tell me
vozaday2000
oh ya and just so you know this is a ze
vozaday2000
well i found where the hose is supposed to hook up in the third picture. but i still can't figure out where the rest go. i think that the hose in the first pic goes to the rad. that small connection on the rad. please correct me if i was wrong. thanks
vozaday2000
also correct me if i'm wrong but does the hose in pic 4 from the egr hook up to the hose in pic 2. it is the top vacuum hose on the egr. i have the bottom hose from the egr hooked up to the throttle body. but i am just guessing here.
jschrauwen
Post by jschrauwen »
Not sure of the first one, although I'm guessing if you trace the solid line it's attached to, if runs to the back of the transmission to a mounting point where a rubber line takes over, my guess would be it's the hydraulic clutch line. Normally it's a solid line all the way along the transmission to the clutch slave cylinder.
Second pic - coolant line running to the back of the engine between firewall and engine.
The fourth pic may be one of the coolant lines for the TB.
Hope this helps.
jschrauwen
vozaday2000 wrote:also correct me if i'm wrong but does the hose in pic 4 from the egr hook up to the hose in pic 2. it is the top vacuum hose on the egr. i have the bottom hose from the egr hooked up to the throttle body. but i am just guessing here.
Shouldn't have any egr lines running to the TB. Just 2 coolant lines. One from the block and the other from an outlet on the thermostat housing.
vozaday2000
no the first pic is not the clutch line it eventually connects to a pole that the second pics hose is connected to. i already have one hose from the egr hooked to the tb but i do not know what to do with the other hose. the hose from the first pic makes no sense at all since the k8 does not have that hose. the hose from the sec pic is on the k8 but i can't remember where it goes and the diagram from the online manual does not show where the hose connects too and also since this is the ze i don't know if it is supposed to hook up to a different area. i don't know.
Gro Harlem
Post by Gro Harlem »
i'm too blind to be able to tell what is in those pics?
higher resolutions photos on hand by any chance?
DONATE TO MX-3.COM
vozaday2000
ya is there anyway i can email you. i can't seem to put the higher res pics on here
vozaday2000
i looked again and i couldn't figure out where pic 2's hose was suposed to connect to. is it supposed to connect to some place on the firewall or does it connect to the engine block?
jschrauwen
vozaday2000 wrote: i already have one hose from the egr hooked to the tb but i do not know what to do with the other hose.
Manual E2-002 indicates at least one of the coolant lines coming from the thermostat housing to the TB although the second one is obscured by the pic. I am quite certain there are NO EGR rubber lines connected to the TB. You may be facing a similar situation like me where someone just slapped a line from one place to another for shipping/expediancy sake. My TB coolant lines fed back into each other bypassing the TB completely - the idiots!!
vozaday2000
where do the egr rubber hoses connect to? i don't understand this. does anybody have there car near them that could take a look and see where these hoses go to. would be greatly appreciated. cuz i can't figure it out/
jschrauwen
Are you not finding any help from the on-line manual?
vozaday2000
no almost none at all. the images are angled wrong. and hard to read. like it is very helpful for most of them but not for the ones i am having problems with. also it doesn't help that i am puting in a klze so i can't just guess where the hoses should go.
vozaday2000
ok i don't know if this helps any but this is what my egr looks like (crudely drawn). I looks like it has one more line than what the one in the manual shows.
