Where does the MAF go on a custom intake?
Posted: March 29th, 2005, 11:49 pm
by seneca
Ok ok ok...I know...I know. I shoudl do a search and all that jazz. Well, I'm impatient! My question, since it's looking like I will be using a Acura integra intake system (2-piece) I've been wondering where the MAF will go? I mean, I know this is probably a silly question...but I just don't see how it will fit in between the two sections of pipe.
And when I did search it in the FAQs' there was no reference as to where this little sensor goes.
Anyone wanna answer this without flaming???
Thanks in advance,
Tyson
Posted: March 29th, 2005, 11:55 pm
by 2fazed
you get the same size cuplers to fit. Measure both pipes, and I believe the VAF is 3in. Ebay sells cuplers if you need different ones.
Posted: March 29th, 2005, 11:56 pm
by relisys_3200
check out babyblue's car domain page...he has a pretty good write up with pictures on the install he did.
http://www.cardomain.com/memberpage/211008/4
(hope you dont mind babyblue)
Posted: March 30th, 2005, 12:52 am
by lakersfan1
In the middle.
Posted: March 30th, 2005, 9:09 pm
by hgallegos915
I saw that page but.. i remember blocking off that plastic elbow coming from befind the vaf.. I used to get a cel light come on once in a while. I unplugged and reconnected and it was all set... it wont matter in this setup? do we need it?
Posted: March 31st, 2005, 9:39 am
by babyblueMX3
if you're talking about the big blue rubber line, it's for the pcv system so leave it there. the other little nipple is for egr so leave it there also..
The VAF goes right in the middle like shown
Posted: March 31st, 2005, 12:31 pm
by hgallegos915
I mean the big black plastic elbow thats next to the disty. Its even labled "k801"
Posted: March 31st, 2005, 1:48 pm
by babyblueMX3
the elbow that goes down in the engine bay that connects to the stock intake tube ? that's only a resonance (sp?) tube..rip that off
Posted: March 31st, 2005, 4:05 pm
by ninjajim4
2fazed wrote:you get the same size cuplers to fit. Measure both pipes, and I believe the VAF is 3in. Ebay sells cuplers if you need different ones.
is there any store to get some extra couplers offline? home depot? autozone?
