dual exhaust?
dual exhaust?
Hey, i dont know if any one asked about this already or not but i couldnt find anything. Does anyone have any info on dual exhuast for a V6?
- mitmaks
I think "mx3 man" has dual exhaust on his mx3, I wouldnt go with dual exhaust unless youve got serious power out of your k series engine
- jschrauwen
Agreed, if no poop to support it, then it's all bling. And that kind of bling is only going to add excess unwanted weight.mitmaks wrote:I think "mx3 man" has dual exhaust on his mx3, I wouldnt go with dual exhaust unless youve got serious power out of your k series engine
i think most people are gonna tell you that a 2.25" or 2.5" single is more than adequte for the ZE... plus, as mentioned before, the added weight to your car will negate any kind of benefit you get from it anyway...mx3tuner wrote:would a klze provide enough power for dual exhaust?
plus don't forget the fact that you then have to do a ton of custom work $$$ ... 2 cats, 2 mufflers, twice as much pipe bending and welding, and plus, i don't even know how easy of a fit it would be... the gas tank might get in the way.... not sure... but if you have the money to spend and u really really like the look of the dual then go for it... even if you're not too handy w/ exhaust work i'm sure u can find some one willing to do it for you, but just expect to pay for it
but unless you're doin something crazy to your engine, then it's not at all necessary IMO... but i agree, the look of it is very very nice
1992 GS/RS Mutant Automatic
There's this rule of thumb I've heard; 1" exaust for 1L of displacement
You have to look at it this way, to small of an exaust is restrictive, to big of an exaust causes the exaust gases to expand, cool and slow down, you have to find a happy medium, which is why i think that rule exists, as a guide
- SE-Man
Not woth it,
go with a single 2.5" pipe to your raer axle, then split to two 1.1/4" dual pipes if you just want the look, click my link below to see what it looks like. The car will have problems ideling if you go with true duals, side ways engines don't work to well with twin pipes, multiple reasons.....
- jschrauwen
Had a look at your site, looks good. You've advertised a weight of 2,200 lbs. I've got to know your secret for shaving nearly 400 lbs from curb weight while adding a wing, body kit and a large sound system. How did you do that?SE-Man wrote:Not woth it,
- SE-Man
Thats racing weight. I don't race with my sound system in it. My front end (Kit) is actually lighter than stock, I also shaved some weight off the ABS front bumper (I cut off the parts that the turn signals screw into. The hood is all fiber glass pin on, no metal frame or hinges. I removed EVERYTHING under the hood that was not needed. Removed all sound dampening, by swaping out spoilers I only added 5 lbs. Light weight rims, removed everything inside and in the harch area thats not needed. Its actually lighter cuz now when I race I remove the entire rear seat now.
As a daily driver I 'm only at around 2300 - 2350 LBs. If its not needed, I removed it, thats how.![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
- vozaday2000
If you want you can just do a cheap dual exhaust. Just run a single pipe (2.25 to 2.5) until you get to the gas tank then split them and run it to the back. Then all you need is one cat and one resinator with two mufflers. or none if your into that. you could also just cut a whole in your pipe to the back behind the gas tank and run a second one to the other side. Just some thoughts.
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
I going for the dual look also. I'm getting a Magnaflow highflow cat and the Deltaflow 40 series from Flowmaster with 2.5" inlet and dual 1.5" (I think, it's written down at home) outlets. I'll run the dual from there and finish with two mufflers. By splitting it at the resonator, I'm making sure exhaust gasses exit from both pipes. It looks really stupid when it's cold out and only one pipe has steam coming from it. I know it's dead weight, but I like the look. ![Razz :P](./images/smilies/icon_razz.gif)
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
