klze filler neck
klze filler neck
I am really tring to advoid swapping the filler necks, because i already have the engine back together. I want to know will drill and tapping the ZE filler neck for the missing sensor and putting one there will work. has any one tried it before. It is because it looks like inorder to get to the filler neck the black casing that is behind the timing belt tensioner needs to be removed along with the timing belt and other accessories.
You can either swap it or drill it, no problem with either one. I tried both for all the klze swaps, bur personaly I prefer swapping, but drilling isn't that much work either.
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
