civic headlight turn signal (what I did)
hgallegos915
Post by hgallegos915 »
Oks it may sound complicated but ok... I made it so that the inner housing where the lights are (the third dome for the turn signal) off while my headlights are on, the only time they turn on is when I use turn signal. Now on the bottom I put the stock amber ones and they are always on like they should. I just wired the civic turn signals to the green wire and negative and walla.. it looks crappy if they are always on, but how I wired them They are off while the stock amber ones are on, when i hit the turn signal they turn on as regular turn signals. Im sure some of you have done it like this, just that I was searching the posts and coudlnt find anything so i did it this way.
-hec
-hec
SE-Man
Post by SE-Man »
I have two holes for turn signals in my Projector housing, one for the old side marker and a new turn signal housing and bulb that I wired just to flash.
