hard start when cold-not only problem
Posted: February 11th, 2005, 1:34 pm
by maddog8664
hi, just bought 92 mx-3 4 cyl. check engine light is on when we bought car-problem is hard to start when cold but when car dose start if turned off before car warms up car will not start again for several hours local parts stores say they do not have diagnostics for that year of car any ideas greatly welcomed
Posted: February 11th, 2005, 2:32 pm
by Joey's mx
Check the diagnostics yourself......black diagnostic box under hood(close to firewall, driverside) use a piece of wire or paper clip and jump it form TEN to GRND!! Turnthe key to the acc position and the code(s) will come up atthe check engine light(longer blinks and faster blinks) let us know what they are they we could help you out more!!
reply to joey on diagnostic
Posted: February 11th, 2005, 3:02 pm
by maddog8664
thanks for info. jumpered TEN -GRND put in acc position check engine light blinked 3 times---and kept blinking intervals of 3
Posted: February 11th, 2005, 3:14 pm
by Joey's mx
so it blinks fast 3 time only or slow?? Doesnt blink slow 3 times then 3 times fast??
Posted: February 11th, 2005, 3:20 pm
by Joey's mx
The code is "no G-signal" I think that it has something to do with the distributor!! Could check for bad cap/rotor, plugs, wires??
Posted: February 11th, 2005, 3:57 pm
by maddog8664
it blinks 3 times slow waits 6 sec. blinks 3 times slow again-does not blink fast slow fast slow
Posted: February 11th, 2005, 4:31 pm
by Joey's mx
OK it is the G signal....like i said i am pretty sure it has to do with the distributor!!
Posted: February 11th, 2005, 11:28 pm
by mitmaks
sounds like problem i had with civic, it turned out to to be cap was cracked, also change your coolant temp sensor, that should help with cold starts
Posted: February 12th, 2005, 1:25 pm
by maddog8664
what would be the best manual to buy for the mx-3
Posted: February 12th, 2005, 1:40 pm
by Joey's mx
CHILTONS=BIBLE
Posted: February 12th, 2005, 2:44 pm
by maddog8664
went to town bought cap and rotor-installed-wiped rotor out by rubbing on the cap bent rotor electrode over to one side -called auto store and he asked about a spacer-did not see spacer on old cap but from appearence of new cap spacer was needed
Posted: February 12th, 2005, 4:11 pm
by neutral
maddog8664 wrote:what would be the best manual to buy for the mx-3
Follow this link & scroll to the bottom for 92 MX-3 Factory Manuals.
http://www.books4cars.com/result2.htm?f ... &Submit=Go
Chilton's can get you through some stuff but can't beat the detail in Mazda Factory Shop Manuals. Not cheap but they pay for themselves many times over. If books4cars is more than you can spend, you'll see em on Ebay every so often usually at well under $50. Either the 92 or 93 factory manuals would cover your model.
