Average compression for a KL-ZE?
bubbaflaat
Post by bubbaflaat »
Anyone know how many PSI of compression the KL-ZE is sappose to have? I average on mine about 200-210PSI. I think that is right where it should be.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
lakersfan1
Post by lakersfan1 »
That's perfectly fine.
DavidOS
Post by DavidOS »
anything below 190 id worry.
babyblueMX3
Post by babyblueMX3 »
I got something in the range of 205-210 when I did the test
RIP 400whp ZE-T MX-3
bubbaflaat
Good to know, thanks! LOL my K8 had 30, 50, and 70 PSI of compression on the front bank of cylinders! Thanks when I decided to go for the KL-ZE!
ccreech
Post by ccreech »
It depends on the age of the engine. I think they came with 180 or 190 form the factory I can't remember which. As carbon builds up that number goes up. I don't think 180-190 is really anything to worry about. Unless it is an older engine and you suspect a problem.
93 GS KLZE Straight Neck (Parked)
Green Turd of MOCA
Car Domain
