WHERE CAN I FIND HEAVY DUTY AXLES FOR MY 92 v6 mx3??? HELP!!
I have a 1992 Mazda MX3 with the 1.8L v6 and a 5 speed. I am getting the block bored, the heads cnc port/polished, a 3pt. grind on the valves, better cams... etc. I need to find a better set of front axles, as i have been told my stock ones won't withstand the abuse. This is my first car(im 16) and it can't be falling apart on me. Thanks for your help!!
- DJester187
TsiMazda told me of this place. He said he's bought several over the years from them and none have broken. Give them a shot.
http://www.raxles.com
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
- bmwm3guy
honestly your axels will be fine... There is no way your car will have anywhere near 200 hp, and I have a KL-ZE with most of the bolt ons (probably around 200-210hp) with my stock axels, and have never had the problem.
In your shoes, I would do your mods, and IF they break... THEN get stronger ones. But I wouldn't worry about it.
I have 310 hp and have not had a problem with axles yet. The tranny diff or gears will fail far before that. And good luck trying to strengthen those. That is the biggest downfall, and the reason I will be moving on to a different car.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Contact BabyBlueMX3, he knows where u can get some beefed up Axles
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- babyblueMX3
I got mine from a local shop around here that makes custom axles..400$ for both. you pick the colour of the boots. For a little more they can make chrome axles
but who would want that hey
RIP 400whp ZE-T MX-3
Can't remember who told me about this site but here ya go http://www.driveshaftshop.com/item135655.ctlg.
92 GS, 210 psi per cylinder KL-101 Engine, Pacesetter Exhaust, Centerforce DF, CAI, Hi Flow Cat, Headers.
By Spring 06: Megasquirt and FPR
By Fall 06: KL-31 Heads with Interprep Cams
Are you serious rebel2k4 of moving on from the mx3? what a DOWNFALL is that.
Curious, is your tranny stock or you did any type of mod? if so, can you share?
Compact Gladiator
"Do not follow the path, instead; go where there is no path and leave a trail"
WWW.GEOCITIES.COM/NEWFLOW81
