Door & Window Seals
Gro Harlem
Door & Window Seals
Anyone know the OEM part number for these parts? If I can get the # i might be able to get them at heavy discounts.
My friggin door makes too much noise when I'm up to speed. This is the 2nd doorseal i've put on it (pulled off a junkyard car as my original was totally messed)
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: Door & Window Seals
I need to replace mine to so if u can get a second set cheap I will pay u a little extra for them!
1quikmx3
I dont know the part number but I could ues a new set as well, if you do get a good price could you let me know. thanks
H&R springs ZX2 struts short shifter 17"s OBX headers flowmaster just waiting for klze time
- jschrauwen
Mine have been pooched since I got it 10 years ago. Early models were replaced due to manufacture flaw. Mazda wouln't replace mine back then.....made do ever since. Constant wind noise when up to speed. Body shop recommended using similar adheasive type material used in installing and securing new windshields. Supposed to work pretty good but was told it was quite expensive. Don't know what the OEM replacement would cost....pretty costly I imagine....maybe a small group buy may be in order depending who could source a good supplier and cost. Ideas???
Gro Harlem
I can likely get hundreds if I only had a part number....
i want both the door AND window seals for both sides...total of 4 part numbers.
I'll probably just goto the dealership and get em manually
DONATE TO MX-3.COM
DONATE TO MX-3.COM
1quikmx3
ya i was thinking about doint the same thing. Im going to got today if I get a opportunity.Gro do you think you should move this to the group buy form?
Nallboy
Just making sure... we're talking about the seals you can see outside the car around the doors and window? The ones that seem to curl up and look like crap, right? I REALLY want a set then. If you can get some sort of GB I'm in! Maybe for two
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
on the home page of this site in the TSB section there is a thing about those seals. I believe they list the oem part# there.
Gro I just called mazda and got the #'s
They are:
DS Door Seal #EA01-59-760D
PS Door Seal #EA01-58-760D
DS Window Seal #EA01-58-60XD
PS Window Seal #EA01-59-60XD
They are:
Guest
I was getting quite of bit of rain inside because the drivers side seal was no good, so, I went to autozone and got the aftermarket weather stripping that fit my mx...... not a single leak since and whisper quite now when driving.... but lacks the outside look of the original seal. Down the road however, I'll probably get the OEM as well from the dealer..... unless of course we start a group buy as mentioned by someone else.
Gro Harlem
Good lord!! I figured they'd be reasonably priced on MMS but I'm wrong
EA01-59-60XD - - $73.30
EA01-58-60XD - - $73.30
EA01-58-760D - - $47.95
EA01-59-760D - - $47.95
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Gro Harlem
BTW: thanks for getting the numbers. I was gonna this break b/c no mazda dealerships are within 100 miles of my college (middle of nowhere, MD) so thx for saving me the trouble
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Is That USD? and the cheapest u can get them?
Ne one what they r regularly in CND?
