I am building a 97 2.5l for my 96 MX-3. i have a PMO 67mm "DE" TB on the way problem is plans changed, i bought a curved neck intake and now fear i wont be able to use the TB.
Has anyone, or does anyone know of someone who has mated a curvend neck IM with a DE TB?
I had a DE Tb on my k8 stock intake. I had to customize one of the metal coolant housings with a dremel. I also had to rotate the IAC solenoid 90 deg's. I never did get that thing to idle right. I just had my stock TB bored out to 60mm and used the Tb plate from the De TB.
Unfortunately you are out of luck. The curved neck manifold uses a completely different shaped mounting point than the KLDE / K8DE and straight-neck KLZE style throttle bodies.
If you look at your manifold, notice how the top part of the mounting position is higher. Thats teh difference.
When I got my curved neck manifold, I swapped my K8 throttle body on to find a huge leak b/c the gasket didn't seal right. I had to source a millenia TB to make it all work properly in the end.
