Mods:
Those look really nice. If you could find a way to streamline the process, you could probably make a nice profit selling it to the rest of us MX-3 owners using polish and cleaning agents on our stock headlights.
This is just a project for me. Barry will have production projector headlights for the rest of Mx-ers soon. I think they will be very cool.<p>If I would make them for other people, I would have to find a way to get clear cover mass-produced, but they are injection molded, and a mold would cost about 10000.00<p>I do not know when I will be done. If only I would have more time.
bump bump<p>are those 90mm hella projectors with hella ff50??<p>im working on a projector setup myself.
i was wondering if the lines on the headlight will effect the beam pattern from the high beam and the projector?
what high beam housing did u use? i have integra high beams but i dont think they will fit cuz im trying to do a dual projector setup with a high beam on each side.
LOW/HI-Beams in HID/Xenon: OEM 2002+ Audi A6 Bi-Xenon projector made by Hella. Barely fits.<p>HI-Beams in Halogen (primarily for reach and FTP): Hella FF50 modules. May not even usem them yet due to various reasons.<p>The fluted lens (with lines) will affect the beam pattern. You need clear lenses.<p>Integra hi-beam may not fit. Because legally they have to be on the inside of the low beam and you know the closer to the centre you get the smaller and shallower it gets. Try Hella 90mm hi-beam module, they are as small and as good as it gets.<p>[ September 21, 2003: Message edited by: JDM ]</p>
all this time i been checkin out hella 90mm projectors but it seems that it slipped my mind that if i dont use the hella's i can still use their high beams. man... i am sofa king wee todd did. hahaha great idea. im still pondering my stupidity.
do u have the ff50 in fog or driving light? hows the beam pattern? im trying to locate something with a nice long driving light that is actually usable when your in the driver seat. ive seen many driving light that look brighter but only light up 5 ft in front, the same 5 feet u dont usually look at anyway when your driving at night. anyone else experienced in auxilliary lighting?
Steeb,
I have Hella FF50 driving lights. I already have factory J-spec fog lights.
If you are still planning to go with a hi-beam integrated into your headlight as in two round projectors, then go with Hella 90mm in H9 type. Run it through the relay, stick with original Osram H9 bulb (not that you will find anything elese on the market for H9 right now) and you will have close to 2000lm output, that is twice the brightness of stock lights (hi-beam), I bet with a better beam as well.
If you do not care for integrating them into your headlights, then bigger is better rule apply here. Think Rally lights. Hella or Cibie has a good range of choices. Just stick with H1/H7/H9/D2S bulbs. Try to avoid anything H3 realted. Yes, Hella makes a few as well, but it is really a fog light bulb and has a transverse filament.
NOw, if you drive in the dark alone for long periods of time, you might want to get your driving beams in HID/Xenon/D2S, whetever you want to call it. And there are cheap options out there. But I will stop here.
