Hey everyone,
I bought a msd sci box back in the day for my crx with the blaster coil. Just wondering if anyone has sucessfully installed any aftermarket ignition in the 6 cyl. If so just wondering if you ran into any problems. Since the box and coil are just sitting there I want to install, but upon taking a quick peek at the stock system it looks like it might be a bit of a challenge.
Thanks
MSD SCI-L INSTALL ****HELP NEEDED****
r1cer4l1fe
- wyldside
Re: MSD SCI-L INSTALL ****HELP NEEDED****
I have the MSD 6A with Blaster II coil installed on my GS. I'm not sure how well yours would work with our system though. It can be a pretty tricky mod if you are unfamiliar with electronics. Just use the search function of the form in the V6/Technical section and look for MSD. That should point you in the right direction.
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6)
Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP
X-Prez of MX-West
