july drag board
- babyblueMX3
july drag board
hey guys I would like to start the july drag board..Send me your time and mod and I'll update the list..Something similar to the april drag board...I am not keeping to old times on there because some are not running their car anymore..so I'll start with me I guess
1. DRAG323 11.98 @ xx.xxx
turbo 14psi
2. Ma-Ze 12.1 @ 117moh---1.8 4cyl,tecIII, built bottom end, racingmazda turbo kit
3. Shady469 13.9 @ 101mph---B6T(with some work done), 13psi, 2.5" exhaust, fmic, weight reduction
4. timpronk 14.385 @ 98.21---klze, klze ecu, ss clutch line, banjo bolt, fuel pressure regulator, cut/welded straight neck ze manifold, ze throttle body, air intake, clutch masters stage1, 17 tsw evo's, khumho, lowered h&r springs. ractive muffler, hi flow cat and reso., 2.5 SS cat back, ss auto headers (v1)
5. Babybluemx3 14.565 @ 94.443 mph---klze (w/ kl31 cams), ze ecu, udp pulley, 67mm TB, 2.25 cat-back, hi-flow cat, CAI, act stage 2 clutch
6.thebonestockkid 14.648 @ 92.98 mph---klde, apexi dual funnel cone/cold air setup, hi flow cat, 2.5 exhaust, gutted hatch, lowered 1.7".
7.steph01 14.69 @ 95.44mph--- klze, reprogram ecu to ze specs, pacesetter cat-back, test pipe, CAI
8. mx3man83 14.7 @ xx.xxmph---klze,straight through resonated 2.5 inch cat back exhaust, CAI, Straight neck IM KLZE, polyurethane filled motor mounts, Kl48 ecu with Eprom chip
9. 14.8@ 95mph w/o nitrous---'92 MX-3 GS, KL-ZE, headers, intake, exhaust, high flow cat, underdrive pulley, lightened flywheel, ACT stage 2 clutch, Zex 75 shot, Primax 17" wheels
10.stang67fb 14.87 @ 92mph---KLZE, LSD, kl36 ecu, all accesories, custom CAI, custom dual exhaust, millenia manifold, poly filled mounts, zex dry 55 shot
11.jaydog5678 14.9 @ 97.6mph---BP-t with Haltech engine managment, stock turbo 12lbs, 3" turbo-back exhaust, K&N intake, Spearco intercooler, stock interior with spare tire, Pirelli P7000 215/40/17's.
12.mx3dohc16 15.0 @ 93.5MPH---B6 DOHC Turbo, ACT Clutch, UDP, Magnecore Wires, Iridium Plugs, Intake, Exhaust
13.torpedan 15.558 @ 88.9 MPH---BPD, Gutted(2290lbs w/driver), Indigo Flywheel, UDP, 1 7/8 exhaust, Nology Wires
<small>[ September 26, 2004, 09:55 AM: Message edited by: babyblueMX3 ]</small>
turbo 14psi
RIP 400whp ZE-T MX-3
Re: july drag board
torpedan 15.558 @ 88.9 MPH - BPD, Gutted(2290lbs w/driver), Indigo Flywheel, UDP, 1 7/8 exhaust, Nology Wires
-torp.
I don't own a Mazda.
Re: july drag board
mx3dohc16 15.0 @ 93.5MPH - B6 DOHC Turbo, ACT Clutch, UDP, Magnecore Wires, Iridium Plugs, Intake, Exhaust
http://www.cardomain.com/member_pages/view_page.pl?page_id=310985
<small>[ July 06, 2004, 08:53 PM: Message edited by: mx3dohc16 ]</small>
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Re: july drag board
After this weekend I'll have my times. I'm guessing mid to high 13's.
My Cardomain site
My Cardomain site
- babyblueMX3
Re: july drag board
good post em when you'll know em..I'll add them to the list
- Shady469
Re: july drag board
13.9 @ 101mph-B6T(with some work done); 13psi, 2.5" exhaust,fmic, on a weight reduction diet. im hoping low 13's with my webcam cams, SPEC flywheel and protege drive train.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: july drag board
i wont bother posting my time from a couple of weeks ago, as in its much worse than last year, ironically enough. best time ever was 14.6@93
with any luck maybe i'll find a way to drop my time .7 seconds somehow this season and see another 14.6... oops, i said too much![Shrug :shrug:](./images/smilies/shrug.gif)
<small>[ July 07, 2004, 04:37 PM: Message edited by: thebonestockkid ]</small>
![Image](http://i5.photobucket.com/albums/y181/hitz1035/s510595978_1374896_9416-1.jpg)
'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
- babyblueMX3
Re: july drag board
that's some good time for a klde ![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
- babyblueMX3
Re: july drag board
anybody else want to add their times??..cmon now..I know a lot of you went to the track this year..keep the times coming ![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
- jaydog5678
Re: july drag board
14.9 @ 97.6 miles an h/r. Best I could do with a missed shift into 3rd..
Street tires - Pirelli P7000 215/40/17's, BP-t with Haltech engine managment, stock turbo 12lbs, 3" turbo-back exhaust, K&N intake, Spearco intercooler, stock interior with spare tire.
![Mad :mad:](./images/smilies/icon_mad.gif)
- babyblueMX3
Re: july drag board
14.7 @ I have no idea how many MPH since they gave out the wrong time slips. That was all motor since I ran out of nitrous before I got to the track and on near bald tires.
My Cardomain site
My Cardomain site
Re: july drag board
heres mine for the july drag board. KLZE,kl36 ecu,all accesories,custom CAI,custom dual exhaust,millenia manifold,poly filled mounts. best i ever hit was a 15.09 at 90mph. then i got a zex dry 55 shot and hit a 14.87 at 92.with my car i have to shift before 6500rpm cause there is no power above those rpms.
Sacramento Raceway, CA
92 Mx3 GS
New Time 13.82 at 101.75 2.205 60ft (RIP beast klze engine)
Updated mods now... KFZE, SS Autochrome Headers and a Sweet a-- 3' Electric Cutout after it, KFZE LSD trans, Millenia manifold, KL36 ecu, Blown motor mounts, custom CAI, Custom ground wire kit, 9mm Plug wires, 2 1/4 exhaust, (Hei and MSD external coil mod), all accessories.
92 Mx3 GS
- babyblueMX3
Re: july drag board
<small>[ July 12, 2004, 05:00 PM: Message edited by: babyblueMX3 ]</small>
- babyblueMX3
Re: july drag board
come on now I want some times ![Froggie Red :froggie_red:](./images/smilies/froggie_red.gif)
