Let Me Know What You Think!
BlazerCrew
Post by BlazerCrew »
I finally updated my cardomain site with my undercar kit. I don't think I've seen any other mx-3 with this kit so check it out. Here it is
Mx-3's rule
BADMX3
Re: Let Me Know What You Think!
Post by BADMX3 »
i like the fact that you can change colours and on your mx being silver this would look nice all the colours>
only problem is you don't get the same glow as from neons and if it rains it lookjs like your being chased by multi coloured fire flies.
However the kit does look good on your ride> congrats > I bet it gets lots of stares.
If you can see the side bulbs i gotta tip for you to make it so you can't see them.
Talon_66
Post by Talon_66 »
Check out Ice Led's there a British company. I believe there underbody LED kits are capable of producing something like 16 million colors
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
papa roached
Post by papa roached »
kool, when does the KL-ZE go in? :welder:
<small>[ September 01, 2004, 02:57 AM: Message edited by: papa roached ]</small>
BlazerCrew
Ya I agree when it rains the effect isn't as nice as with neons. But I like it is different and not everyone has these. Another reason I like these so much is that they were even cheaper than the street glow gold series I was planning on getting. I got these for $260. And I believe the Ice Led's are a lot more. As for the KL I don't plan on doing it now but I plan on garaging this car when I get older and maybe I'll have enough money to drop into it.
Mx-3's rule
