camber correction
Posted: April 21st, 2004, 2:04 am
got my camber bolts in the mail today, just want to make sure that they go in the bottom bolt hole, i am pretty sure but not positive. also is there anything else i can do to the rear to correct the camber its out -2, with the bolt it should bring it to -1. with the front i can turn the strut mount on the top to fix it along with the bolt to correct it but need to know if there is anything else that i can do, thanks.
