Re: Tranny Fluid
Posted: May 1st, 2003, 11:19 am
by torpedan
Yeah you can get it flushed.. Sevral manufactures use Dexron for there manual tranmissions although the mx-3 is designed for gear oil.. Hondas use motor oil =] fords usually have Dexron though.. Although atf is a lighter fluid and will hae less parasatic drag
Re: Tranny Fluid
Posted: May 1st, 2003, 12:19 pm
by JonGordo8
ford's use mercon...but than again now most ATF is mercon/dexron
Re: Tranny Fluid
Posted: May 1st, 2003, 6:54 pm
by torpedan
stifling the temptation to edit the message to an m and senduin you back a message sayin wtf... =]<p>
shhh dont notice the spellin =]
Re: Tranny Fluid
Posted: May 3rd, 2003, 12:01 am
by JasonH
Redline MTL is the stuff to use. Your tranny will thank you.<p>[ May 02, 2003: Message edited by: JasonH ]</p>
