![Surprised :eek:](./images/smilies/icon_surprised.gif)
Coilovers...how's it done?
Hey guys, <BR> does anyone have pictures of their coilover setup? The only coilovers I am familiar with are the type you would put on a T Bucket or deuce coupe. I can't bend my brain around how that would work replacing a strut. I mean, the strut has to be rigid on the bottom and mount through the strut tower on the top, and coilovers (at least the ones I have used) mount just like a regular shock on both ends. Does it really, honestly do anything for the performance of the car? I've noticed that my little mx'er feels really, really loose in the a-- end, like the rear is letting go of the street in a hard corner.
It's not really, so I've just become used to the sliding sensation. Would a rear tie bar alleviate some or all of the squirreliness? I bought my car from my daughter about a year ago, and have loved every second of it. However, I know she tagged a highway barrier pretty hard on the passenger side a couple of years ago. She had it fixed by a reputable shop, but I have noticed some problems. I thought that the looseness in the rear was because something was not put back together right, but I have since noticed that my driver's side rear tire wears on the inside. The top of the wheel is leaning into the body ever so slightly... is there a way to correct this, or is something bent? Thx!
Jason B
1993 MX-3 GS
1.8 V6 5 speed
1993 MX-3 GS
1.8 V6 5 speed
Re: Coilovers...how's it done?
A strut suspension is inherently a coilover. It would therefore be a total waste of time to replace the strut with a coilover shock as the hot rods have. Adjustable springs like Ground Control and Weapon R are often referred to as coilovers but like the first two words say, they are basically adjustable springs.<P>Sounds like your MX was indeed repaired inadequately. My GS is not tail happy at all. The V-6 models already have a lower tie bar. Better have a shop check out the alignment specs on the rear and have them recommend a solution. Good luck!
