I just took a drive in my buddy's 2004 toyota corolla and the speaker system is just what im looking for!
Would it be possible to buy those speakers froma toyota dealership and put it in my mx-3?
Would it sounds the saem or would I need a aplifier?
Speakers
- papa roached
Re: Speakers
you can build a sound system for your MX for less than what you would pay at a toyota dealer
Re: Speakers
I was just wondering if anyone knew the specs of the stock speakers (watts)?
Re: Speakers
sash give me a holla, i have a hook up and i can get what you want. ill hook another MX3er up, matter fact all of you guys. if you need amps subs speakers tvs navigation systems let me know
-Chris
-Chris
