Anti-Sway Bars
Anti-Sway Bars
Hi,<P>I'm just curious if anyone has anti-sway bars installed in their car? If yes was the installation fairly simple bolt on? Also is there any company other then Mazdaspeed that makes them? Thx in advance.<P>Soulflare
Soulflare
Pearl MX-3 GSR (SOLD)
Mystic RX-8 GT
Mystic RX-8 GT
Re: Anti-Sway Bars
No other companies make any sets for the MX3. However, if you look in the back of Sports Car or Grassroots motorsports, you should see plenty of places that would build a custom one. They would probably need the car for a bit, to take measurements, but you would be able to get exactly what diameter bar you wanted and such. Price would run probably about 200 bucks.
-93 MR2
#129 E-stock
#129 E-stock
Re: Anti-Sway Bars
Yeah, I tracked down a local company who would do them whatever diameter I want with custom endlinks for ~$175, but they have to keep my car for a while for measurements and test fitting.
David Coleman
Re: Anti-Sway Bars
a company here in Austrlia do them, they are custom making a set for me, eventually, once they get the measurements etc, they can make 'em as they please... from memory I think they are about $162 Australian, and they will ship to the US.. <P>Go to <A HREF="http://www.whiteline.com.au" TARGET=_blank>Whiteline</A> and get some more info from there.. you'll notice they don't have any products listed for the MX-3, but they will custom make. <P>Hope this helps..<P>@ds
- EUNOS 30X -
Re: Anti-Sway Bars
I looked through the whiteline Aus site today. I've read a few posts from poeple that have gone to them for suspension mods for their 30x's. Are there any more place you can refer me to in Australia that eunos users have used? I'm planning on trading my ATX for a MTX in a few years, then modifying that a little.<p>What an awesome car!!<p>cheers.<p>[ December 30, 2002: Message edited by: ausDriver ]</p>
Re: Anti-Sway Bars
i have whiteline rear sway bar,it's great
92 yellow mtx klze presso,K&N cone filter,KLZE ecu & intake manifold,whiteline front & rear strut bar, apex spring,koni strut,whiteline camber bolt,WHITELINE rear 22mm swaybar,magnecor 8.5mm sparkwire,2.5" custom catback,custom testpipe,FSE fpr,sard oil gas tank,apexi S-AFC,15"RAYS TE37 rim,FALKEN ST-115 tire,EVO4 front brake,mazdaspeed seat,mazdaspeed steering wheel,mazdaspeed front nose
Re: Anti-Sway Bars
Where do you get them? I wanna get atleast some rear ones before spring, and the front ones i want "KLZE Ready". I've seen a blue one, im not sure if it was front or back, but that would be cool
Re: Anti-Sway Bars
Re: Anti-Sway Bars
MAZDASPEED makes both front and rear swaybars for the MX-3. www.corksport.com
Re: Anti-Sway Bars
Try SRD for anti sway bars
IF LIFE DOESN'T OFFER A GAME WORTH PLAYING, THEN INVENT ONE.
Re: Anti-Sway Bars
What the diff between anti-sway and strut bars?...
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Re: Anti-Sway Bars
simple explanation:
anti sway bar is under the car and controls body roll.. <p>
<p>strut brace is on top of the struts, between the two strut towers.. they keep the things tighter and stiffer in general.<p>there are much better, and more informative posts out there on this.. <p>![Image](http://members.optushome.com.au/eunosads/rearbrace16.jpg)
![Image](http://members.optushome.com.au/eunosads/strutnos.jpg)
![Image](http://members.optushome.com.au/eunosads/newbar2.jpg)
- EUNOS 30X -
Re: Anti-Sway Bars
eunosads thanx still alil lost but i just get both anyway i want tight steering...(3 dots)
