Racing Mazda Turbo Kit
Hey guys, finally got pics of my car up.
http://www.cardomain.com/memberpage/652555
Should have a video up soon with an 11 second pass. Shooting for 9's by next race season and we will be running in the nopi turbo 4 class along with nhra spfwd.
<small>[ August 12, 2004, 08:13 AM: Message edited by: Ma-Ze ]</small>
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
Re: Racing Mazda Turbo Kit
wow
i can't believe your still using the stock manifold with that much hp![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
- BuGS
For some reason i thought you still had the SOHC engine. but i am guessing that it the bp engine then you turboed that??? Plz explain. Thanks!
- papa roached
thats not the stock manifold
intake manifold
2004 RX-8 - Project
2004 RX-8 - Project
It wont be there much longer, after i get my new head and roll cage put in, ill be getting a new intake manifold.Originally posted by Marlon:
wow
i can't believe your still using the stock manifold with that much hp![]()
92 MX-3 RS,
- mitmaks
man thats nice setup how much it cost you?
- Josh
was wondering what ignition system are you using, and what are you using for fuel management?
man yall should advertise these manifolds on other mazda sites as these turbo manifolds will sell like hotcakes. if and when i upgrade my turbo ill def be getting me one of these with the turbo :p . very nice setup from what i can see!!!
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
man iraq sucks!!!
95 MX-3 RS
man iraq sucks!!!
- jaydog5678
Tec III(Electromotive)...Originally posted by Josh:
I'd have to say a really good engine management at that.
If I get enough request on the manifold. I might sell them. It is a race set up so it will not fit with A\COriginally posted by natural born honda killer:
Proud builder of
455 hp Miata 10.98@125mph
MX-3 RS 25 psi 451 hp
MX-6 F2T 12.8 @ 112 mph
(Current Project) A 700 hp MX-3 now at 475 hp
yah, whats the price for the upgrades to make it a 10 second car
<small>[ August 13, 2004, 11:23 PM: Message edited by: Vanshed ]</small>
- jaydog5678
I'm interested in the exhaust manifold...Originally posted by Minimonster:
And I'm not using A/C. Does it have any bracing to support the weight of the turbo(a bracket from the block to the manifold or turbo)?
yea it has support. if you look closely at the pictures of the manifold you can see it on the right side.Originally posted by jaydog5678:
92 MX-3 RS,
- Josh
thats exactly what i want. if i don have to make it then thats better on me. but i got the 1.6L. my man has a crack, got it welded but she cracked again. loss of HP. its not too bad but i need to do something soon. about how much do you think thies will run if you decide to make them.
