ITS ALIVE!!!!!! (for real)
- Shady469
*joy* its running! no smoke, idles, and drives. BUT!(you know there would be one..) it will go fine partial throttle until like 3,500/4k then boggs and doesnt want to idle.im thinking thats its a combo of the s-afc and that the bov leaks at idle(havent had time to weld on the blitz and cant recirculate the stock one). but man oh man its nice to hear a turbo spool...<p>[ April 17, 2003: Message edited by: Shady469 ]</p>
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: ITS ALIVE!!!!!! (for real)
Its the headgasket. If you know how to change the timing belt on your car,then you can change the headgasket yourself.
JWMotorsports
No it isn't the head gasket. I had to change several settings in the Super-AFC. It was running so rich it was almost killing it! It's running MUCH better now, but I can't tune it till he gets a new O2 sensor. A few little things hear & there & it'll be read to take to the strip.
- Shady469
yeah make sure you read the instructions for the S-AFC
many thanx to JWMotorsports... without his help i know it wouldnt be running.
hit another bump in the road... the 1st injector had a little leak at the manifold so i cranked the fuel rail on down and, yep you guessed it, snapped the bolt.i replaced the o2 sensor and its still reading rich... i think i need to tap in at the ecu harness.
it was a bunch of little things that kept her from running and now a bunch of little things kepping me from driving... but she runs and man o man does she purr....
