				turbo klze/kl03 Q
				Posted: February 17th, 2003, 4:39 am
				by MXKreepscort
				Im new at this but would someone explain to me why its so hard for someone to TC there klze, and would it be as hard to TC a kl03?
				Re: turbo klze/kl03 Q
				Posted: February 17th, 2003, 9:43 am
				by Sonicxtacy02
				<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by MXKreepscort:
 Im new at this but would someone explain to me why its so hard for someone to TC there klze, and would it be as hard to TC a kl03?<hr></blockquote><p>your question can be answered from two approaches.  Physically its hard to turbocharge either engine because of the room in the engine bay.  There are no turbo kits for our car so it would be completely custom work.   Theorectically, the ZE is harder to turbo and effectively tune because of its higher compression.  The 03/DE has lower compression so it allows higher boost pressures and is easier to tune.  Read the Forced induction FAQ for more info
				Posted: February 17th, 2003, 4:08 pm
				by VizualXTC
				The KLZE has a 10:1 Compression Ratio (CR) which some people deem to be "too high". The KL03 has a 9.1:1 CR which is bore "boost friendly". The lower compression ratio will leave a higher margin for error. Although you will realize higher gains from the higher compression engine. Take time and look at all the turbo kits for the b16 and b18 engines. These engines have 10.2:1 and 10:1 respectively. It's not hard to turbocharge the KLZE. It's just more precise than the KL03. <p>Look in the FAQ pages about this. There are a few people that have custom made turbo setups that have provided their experience and design to further our knowledge.
				Posted: February 18th, 2003, 10:21 am
				by davidosk024
				what a load of **** really <p>compression, WHO THE HELL CAREs!!!!<p>when you goto buy your forged pistons, rods,
 bolts and crank to turbo your car...
 your gonna decompress the engine to do it
 anyways. <p>Its gonna be custom not matter what and its gonna cost $$$ not matter what.
				Posted: February 19th, 2003, 1:46 am
				by pelado
				It is entirely possible to turbo a KL without buying expensive items like new pistons and con rods.
				Posted: February 19th, 2003, 2:46 am
				by VizualXTC
				Sean Matthews has 8psi on his stock KLZE
