Will the side repeaters (the ones on the fenders)
from a Protege be a direct bolt on on a 93 MX3?
Like the ones in the lighting section on corksport
Side repeaters
Side repeaters
Odds, Norway
Red `93 GS, Stock
Red `93 GS, Stock
Re: Side repeaters
the ones on the mazda 6 are a pretty good fix
check my car domain
http://www.cardomain.com/ride/2144443
Re: Side repeaters
Mazda 6 works nice. just remove the old ones, use something with a sharp point, and get the "contacts" out of the plastic plug that goes into the sidemarker.
Then use a heating gun to heat the part on the sidemarker that`s supposed to be tight against the fender, as its a way too tight fit if you dont.
Lastly, just push the contacts on to the pins on the sidemarker, and use some electrical tape on both wires so they don`t short anything if they touch eachother.
Odds: I`m selling my 2-piece Postert wing really cheap if you are interested.
nope-mx3
nope-mx3
