Rim and Tire sizes??
If I get a set of 17"s, whats the ideal tire size that I should go for??
Do 18" look too big??
Whats every one running on? Pics would help.
Re: Rim and Tire sizes??
for pics of cars with 18s... check out this thread.... 18" wheels
also check out the Tire size calculator
hope this helps.
Cheers,
hope this helps.
Cheers,
205/40/17Originally posted by MikeUK:
- atlantamx3
not always Chris,
a 17x7 wheel should have a 205/40/17... while a 17x7.5 wheel should have a 215/40/17.
I have 17x7.5 Konigs, and 205/40/17s and they are too small.
according to that calc. You would need 215/40/r17 or 205/45/r17 to keep within 1% of your stock speedometor calibration
Tom Alexander
Cheers every one.
i have 215/40/18's, i have da tenzo shu-4's in white
93' Mx-3 GS, repainted laguna blue with pearl, 18 inch wheels (white) with Falcon ZE512 ruppers, custom headers with 2 1/4 inch exhaust, ported TB and intake manifold, ACT clutch, and ground-control coil-overs.
also fits wit my ground-control coilovers all da way down wit milimeters ta spare, and 18's dont look too big, they look great on the mx3, if anything, i think the 17's look a little small, but thats just me.............
hey mat i have got 8x18 inch alloys with 235/35/18 tyres on them and there is not much room for any bigger i would stick to a smaller size tyre if i was you
Pakfeifer new front bumper, Pakfeifer new rear bumper, Pakfeifer new side skirts, Pakfeifer new bonnet, Pakfeifer new rear spoiler , Pakfeifer rear clear lights, Lowered 60mm all round, 75bhp of Nitrous, Green induction kit,18 inch wolfrace chrome alloys , Twin exit exhaust, Full two tone leather interior, One off custom ice install, Mondena corsa steering wheel, sparco gear knob, richbrook gear handle, white dials, sparco red and silver pedals,
215/40R17 would be the closest to the diameter of the stock wheel/tire combination, the 40 (sidewall height)being the aspect ratio or percentage of the 215 (width of the tire), which is 3.4 inches, added to each side of the 17 inch rim, which is 23.8 inches, same as the diameter of the 205/55R15 which comes on an mx-3 gs...or you could just use that tire calculator, which is alot easier!
Cheers every one, Ive ordered a set of 18" ADRs with 215/35s.
These ones
<img src="http://images.cardomain.com/member_imag ... 2_full.jpg" alt=" - " />
These ones
