The last time I attempted to install my reverse glo gauges I bought from Speedhut, I got them in and working but broke the needle on my fuel gauge cause I couldn't figure out how to get the new face over the 2 needles and the pin for the clock controls on the fuel/temp gauge.I really don't want to have to do this again so I'm going to ask those of you who have done this successfully, how did you do it? Any suggestions would be greatly appreciated.
Cheers
Speedhut gauge installation question
Second place is the first loser.
- 2fazed
Re: Speedhut gauge installation question
The easiest way is to unscrew the three screws on the back to the fuel and temp gauge. You can then move them to line up while you slip the face on the needle. I have the Speedhut ones, and they fit perfectly.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
That junk isn't too hard. I slid the guage over the clock pin, then I just moved the needles around until they both went through. Just a little play time, that's all. When you hook up the power for the transformer, make sure you hook it up behind the illumination control. You can catch parking lights at the harness at the top of the fuse box, and it will read 12V, but it doesn't carry enough current for the Xformer. Enjoy.
yea you just have to play around with the temp and fuel needles for a bit, they will go, just be patient, and they are pretty flexible too. i just wired mine up to the wires right behind my dimmer switch, worked fine for me..
Ditto that. Worked for me as well.Originally posted by 2fazed:
