My hatch rattles like none other.
I already tried adjusting the latch (on the body of the trunk), but it doesn't solve it for very long. If I put it too low it makes it hard to close, and it still squeaks.
Also, I put teflon tape around the latch on the hatch. That worked for a little while put the tape wore through.
I bought the rubber bushings (what the hatch sits on) off a 94 that looked like they were in better condition. They didn't do anything.
The only thing I can think of, is that on the actual hatch there are little rubber pads/stickers that are worn off.
Does anyone know if buying these will solve the problem? Or if there is another way around this problem? There must be someway to make like it was when it was new.
Thanks.
Squeaky Hatch!!! Possible Fix?
Re: Squeaky Hatch!!! Possible Fix?
This works on Integras...try it here. Wrap some duct tape (100mph tape
) around the latch on the hatch. That may work, worth a try at least.
Anthony
MX6? Maybe soon.
I Can Install Parts And Build Custom CAIs.
[email]Gwathnar@hotmail.com" target="_blank[/email]
MX6? Maybe soon.
- guyaverage
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
I used waterproof tape and it worked better than the plumber's tape. I looking for something a little more permanent. This will have to do until then.
The TSB says it was for 93's.
Does anyone know the price for the hinges, otherwise?
thanks for the help
thanks for the help
