polished valve cover
mazdamxstyle
Post by mazdamxstyle »
hey guys plz dont bash me for asking this but how do I polish my valve cover once its taken off? i want to give my engine a much cleaner look instead of just painting it i wanna polish it. what things do I need and how much are they? any info would be awesome thanks guys!
1993 Mazda mx-3 GS - Blaze Red (Totaled) Went through an 89 rx7 and a 93 del sol. Now searching again!
http://www.cardomain.com/id/mxmisl
MAZDASPEED STEVE
Re: polished valve cover
Post by MAZDASPEED STEVE »
You're gonna want to start with a couple sheets of low grit sandpaper(100-200) and work your way up to a higher grit sandpaper, basically wet sandpaper(1500-2000). It'll take a while and will be kinda tricky getting into all the grooves and corners, a die grinder would help alot and cut back on time. Good Luck. :D
THANX
MAZDASPEED
STEVE
VizualXTC
Post by VizualXTC »
I'd get it professionally done.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
mazdamxstyle
after a days worth of sanding whats the next step? i just need a little more info but thx for the help so far. ;)
blikmik
Post by blikmik »
I polished mine... trust VisualXTC.... get them professionally done... it's not that much $$$ and saves you a HUGE amount of time!! By the way ... they do look sweet when they're done.. I accented mine with powdercoating around the emblem!!!
mazdamxstyle
what type of shop and how much does it cost for a professionally done job?
mrprecidia
Post by mrprecidia »
i had my two valve covers and my intake manifold done for about 300 cndn. you take them to a polishing shop look in the phone book.
You can just call me the originator
blikmik
Post by blikmik »
Also chroming/plating shops do polishing as well..
Return to “Appearance”
